Old Oct 12 2011, 11:25 PM
Arrow Neighbors, Super Neighbors, & Buddies
This thread is for reporting problems concerning neighbors. Please read the following information BEFORE posting in this thread. Thank you!
Post Release Updates May 5th, 2023 - Expanded Neighbours capacity by 33%
Please make sure that you have read the information in the Web Guide to see what differences there are, now that you are playing Farm Town on the Website!
Check Out The Game Guide:
Chapter 05 - Neighbours and Buddies Farmer Lists
Everything you need to know about Neighbours, Buddies and Farmer Lists.
Chapter 06 - Super Neighbours
Everything you need to know about Super Neighbours.
Need More Neighbors? Go here: Neighbour/Buddy Requests!
NEW!!! Going on Vacation and won't be able to play for a while?
Set your status in game as unavailable for up to 3 months. CLICK HERE
Thank you!
Important Things to Remember:
1. For two players to become neighbors with each other, BOTH players need to send out and accept neighbor requests.
  • If you want a friend as a Neighbour, YOU must send the request for them to accept.
  • If they want you as a Neighbour, THEY must send you a request for you to accept.
2. The Neighbors and Buddy Limits are based on how many digits the database can hold, it varies because not all IDs are the same length. ID's are normally 8 to 17 characters in length, so the number of neighbours/buddies you can have can vary. You should be able to have a minimum of 117 neighbours and in most cases for more than that, depending on the ID's.
You could have roughly up to 500 farming friends which will be a combination of Neighbours and Buddies.
When you reach your limit of neighbors, and you try to add another, if there is not enough room in the database to add the farmers ID you will see a brief notification that tells you
"Your Neighbour List is Full, please delete some neighbours before adding more."
When this happens, you can not add more neighbours.
What you CAN do, is see if any of your current neighbours have stopped playing. If they have you can decide whether or not to replace them with someone who is currently active in the game.
To change your neighbours, you will need to remove some before you can add more.
Look in the Farmers List My Neighbours section and see who is still active in the game their activity date will be showing, if you do not want to lose them as a connection in the game see if you have room to move them to your Buddy List instead.
You can also check your Buddy List to see if you want to change a Buddy to a Neighbour.
3. The Super Neighbors Limit is also based on Neighbours ID's. Approximately 20 Neighbors should be fine. If you try to add a super neighbour and have run out of room to add any more you will see a popup telling you that.
  • To find out how many Super Neighbours you have, click on anyone's picture in the Neighbours bar at the bottom of the game screen and click on "Order by Super-Neighbour". Then count all the ones with a red dot on their picture. You may need to scroll the Neighbours bar if you have more than a few.
  • Neighbours with purple dot are the friends who have set you as their Super Neighbour.
  • To find out what all the coloured dots mean see the following post in the Game Guide: https://r1.slashkey.com/forum/showth...22#post6548322
4. If you want to remove someone from being your Neighbour or Buddy make sure you remove yourself as being their Neighbour and Buddy, before you remove them from your OWN Neighbour or Buddy List.
You will also need to remove them from the Facebook Friends list in your Farmers list if they are showing up there as well, after removing all the Neighbour/Buddy connections.
Remember that the Manage option on gifts/trains/ships etc that you may have sent can allow someone to add you back so make sure that you have removed them from ships logbooks, that you are not sending them train boosts or returning gifts to them.
Instructions, on how to remove Neighbour and Buddy connections are in the following link:
https://r1.slashkey.com/forum/showth...10#post6548310
5. Archived Farms. Farms that have not been played in some time will become 'archived'. So if you notice a neighbors farm is empty this is likely what has happened. You will see a message telling you what the farm owner needs to do. Once that user visits the game, their farm will be reinstated.
6. Visiting/Tending Neighbors. You earn 30 XP for each neighbor whose farm you tend (watering, raking, etc) within a 24-hour period up to a limit of 100 visits. After that you will earn 1 XP. You can only tend each neighbor once a day.
This thread is for players to report problems or questions only. Any off topic posts will be removed by a moderator without notice to the user.
archived farm, beige dot, blue dot, can't add neighbour, colored dots, coloured dots, dots, green dot, invite, marketplace, need jobs, neighbor, neighbor requests, neighbors, neighbour, neighbour request, new neighbours, purple dot, red dot, remove neighbour, super neighbor, super neighbor tools, super neighbors
