Go Back   Farm Town > Languages > Other Languages > Deutsch
Old Nov 12 2016, 11:34 AM
tom.schupbach@gmx.net tom.schupbach@gmx.net is offline
Default Problems with plowing and sowing
Hi, about 25% of my farm # 28 stay in the status "harvested". If I plow and sow this part of the farm, it is shown as seeded....but if I refresh the farm it is again "harvested".......the other 75% of this farm work well.
What do I do wrong? Thanks for your help
Old Nov 12 2016, 11:51 AM
Hi Tom
Please try the following suggestions
-. Try clearing your memcache (link below), you will see a list of unsettings, that means your game memory is cleared. Close that window and your farm if it was opened during the clearing. Then reaopen the game and try to plow and seed that part of the farm and refresh to check if it continues seeded.
-. If after doing that, that part is still showing up as harvested, then delete one or two harvested spots, refresh the farm and check if there is another crop below. If you find another crop then you have to continue the process and harvest it.
-. If you dont find another crop then the best thing to do is to delete all the harvested plots, refresh the farm, and check if any of them are there again, if they are, then you have to delete them, and refresh and continue doing this till you see only green. Then you can plow that part again.
Please let us know if those suggestions worked for you.
Old Nov 13 2016, 10:56 AM
Default perfect solution
Thanks for your fast reply and your solution-ideas.
#2 (delete, refresh...and there was another crop...:-) worked perfect!
Happy farming from Germany
Old Nov 13 2016, 12:05 PM
Hi Tom
So glad it worked for you and thanks for coming back to let us know.
Best regards from Argentina
Old Jul 19 2024, 07:31 AM
Brigitte123 Brigitte123 is offline
Default Loose Fields
Hi, i need help please
When i plow Fields and i sow and next day i harvest, i loose Fields.
I doing everythink
what can i doing ?
Old Jul 19 2024, 09:02 AM
I doing everythink
what can i doing ?
Hi Brigitte
I visited that farm and can see there is a row of plowed fields next to the rivers which are not showing up.
Is that the problem you are talking about?
If it is, then please run memcache, link below. A new window will open with a short list of unsettings. Close that window and your farms in all tabs you have it open. Then reopen your farms.
After that, plow that row. Reload the game and see if they stayed.
If they stayed, then plant the crop you need and see the problem is fixed next time you harvest them.
