Old Oct 20 2009, 02:36 PM
Raul Raul is offline
Default New Release -- October 20th, 2009
Hi,
We just released a new version of FarmTown. (As usual, you will get the new version when going to FarmTown the next time).
The new release contains support for 5 different tools:
1. Small Harvester - Harvest 2 fields at a time
2. Small Seeder - Plant seeds on 2 fields at a time
3. Big Harvester - Harvest 4 fields at a time
4. Big Seeder - Plant seeds on 4 fields at a time
5. Plowing Tractor - Solar Powered - Plow 4 fields at a time
All the tools works in a similar way, you just need to click on the tool and select the first option which could be Harvest, Plant Seeds or Plow depending on the tool. Alternatively, some of the tools can also be activated by clicking on the appropiate icon on the main tool window at the bottom of the screen.
The Plowing Tractor doesn't require fuel to operate so you can use it as much as you want without any limitations. The others require fuel to operate, these are the rules for the fuel:
1. To get fuel you need to go to the fuel station by clicking on the red fuel tank on the top-left of the screen or on the map icon
2. You can refuel once per day
3. The amout of fuel gallons you receive each day depends on these factors:
10 Gallons for each level you have accomplished
10 Gallons for each neighbour you have
10 Gallons for each friend you help each day
10 Gallons for each active neighbour in the last 24h
100 Gallons for each fuel tank you receive from your friends
If you are having trouble, remember to link your account.
Thanks.
Moderator Edit: We have an established thread in the help and support section where we will attempt to answer any questions that you have about these new features. http://slashkey.com/forum/showthread.php?t=238278 Mods will not be answering questions posted in this thread from the developers.
Old Oct 20 2009, 02:47 PM
Wild's Avatar
Wild Wild is offline
THE NEW FARM TOOLS
Where are the new tools?
The tools are all found under the Tools tab on the store page.
How do I get the new tools?
The tools are all available for purchase with farm coins.
What do the tools do?
All tools work for you on your own farm. They cannot be used by hired help.
  • Plowing Tractor - Solar Powered: Gas free plowing tool that allows to plow up to 4 fields at a time - no matter how many neighbors you have!
  • Small Harvester: Harvesting tool that allows you to harvest up to 2 crops at a time. Each field consumes 1 unit of gas.
  • Big Harvester: Harvesting tool that allows you to harvest up to 4 crops at a time. Each field consumes 1 unit of gas.
  • Small Seeder: Seeding tool that allows you to seed up to 2 fields at a time. Each field consumes 1 unit of gas.
  • Big Seeder: Seeding tool that allows you to seed up to 4 fields at a time. Each field consumes 1 unit of gas.
How do I get fuel?
Click on the map then click on fuel station or click on the fuel can under your coins and farm cash displays. You earn fuel in the following ways:
  • Your Game Level: Your level X10
  • Neighbours: Number of neighbors you have X10 also.
  • Friends helped: Number of friends that helped you that day X10
  • Active Neighbours: Number of neighbors you have that were active that day X10
  • Fuel From Friend: Gift of fuel tank
Once you accept a fuel can as a gift from your facebook/myspace page, it will appear in your gift box AND you will see credit for it under the tank (pictured below). Clicking on it from your gift box will not take it out of the gift box, but will bring you to your "gas stattion/tank" to show you how much fuel you have available for your next refueling. The gas can will remain in your gift box until the next time you refuel. When you refuel the credit will transfer from your "gas station/tank" up to the fuel counter under your farmtown cash and the fuel can will disappear from your gift box.
When you click on the fuel station on the map, the fuel icon in the top left corner of your screen, or a fuel can in your gift box, you will be shown how much fuel you have earned and available for the day. You have to click on the refuel button to fuel your machinery. You can only refuel when it tells you that you can and any fuel already showing in the upper left corner of your screen will be lost. The total from your fueling station/tank will replace (not add to) the amount of fuel you have to use.
Various comments
  • Once you purchase the Tractor, your plowing tool gains the X4 option, without the need for neighbors.
  • Once you purchase the Harvesters, your harvesting tool gains the X2 and/or X4 options (depending which one you bought). If you have only the Big Harvester, you cannot use the X2 harvest option.
  • Once you purchase the Seeders, you need to click on them to open a special store to select the seeds. Using the regular store will trigger the X1 regular seeding tool.
  • All tools rotate.
  • Charges for plowing using the equipment are the same as if you were plowing yourself without the equipment. You do not save the money per plot that you save when you hire someone else.
  • The amount you get for each crop when using the equipment is the same as if you harvested it yourself without the equipment. You do not get the extra money per crop that you get when you hire someone to harvest for you.
  • If you have your fields plowed up against each other with no space between them, you must have your preferences set so that there is a check mark next to "Remove Spaces Between Fields" before selecting the seeder or harvester.
  • If you have your fields plowed with space between them, you must have your preferences set so that there is NO check mark next to "Remove Spaces Between Fields" before selecting the seeder or harvester.
Prices and other info
  • Plowing Tractor - Solar Powered: Cost 60,000 coins Give 601 XP Sell for 1800 coins
  • Small Harvester: Cost 15,000 coins Give 153 XP Sell for 450 coins
  • Big Harvester: Cost 30,000 coins Give 302 XP Sell for 900 coins
  • Small Seeder: Cost 20,000 coins Give 203 XP Sell for 600 coins
  • Big Seeder: Cost 40,000 coins Give 402 XP Sell for 1200 coins
There are questions regarding the exact meaning of "Friends Helped", we will be contacting the developers to get the final answer and will post that answer here in this thread.
We will also be reporting the fact that some of you are receiving a message that you do not have fuel even after you have gone to the fuel station and fueled up.
Some of you have reported that you are not able to use the fuel you have been given as gifts. We will be reporting that along with the items above.
**Please note that losing fuel you already had showing when you refuel, is NOT a glitch. Refueling REPLACES the amount of fuel you have for use in the upper left corner with the amount showing available in your fuel station. It does NOT add the two together.
Old Oct 20 2009, 02:49 PM
chipcataldo chipcataldo is offline
Do these work on other people's farms when you're hired to harvest?
Peace,
Chip
Old Oct 20 2009, 02:53 PM
Yo's Farm Yo's Farm is offline
Chip,
no it doesnt
ash_sk8s ash_sk8s is offline
Awesome thanks!
Old Oct 20 2009, 02:54 PM
Wow, what's the point, then? Unless they're going to greatly expand the farm size, I see no need for the harvesters.
Peace,
Chip
cagirl cagirl is offline
Question
Originally Posted by Raul View Post
Hi,
100 Gallongs for each fuel tank you receive from your friends
Thanks.
Question: Are these for use on our own farms or can they be used when hired for work on other farms??? A large percentage doesn't harvests/plows their own farms these days!!!
Old Oct 20 2009, 02:56 PM
Capt. Conor Capt. Conor is offline
Peace,
Chip
same here, not to sound ungrateful but i would want more crops and levels and land before machines
Old Oct 20 2009, 02:57 PM
gottawatchlost gottawatchlost is offline
Thanks for the tools. I bought a small seeder already. I'll try it out tomorrow.
Old Oct 20 2009, 03:00 PM
Woody83 Woody83 is offline
How come it appears the large machines are charging $3 to purchase yet this is not showed when you're buying?
