  #2021
Old Jul 26 2023, 06:06 AM
Originally Posted by LisaScobee View Post
2023-07-26 05:39:25.200 INFOCheckpoint-B-000 - Initialized
2023-07-26 05:39:25.202 LOGFT Client Services Inited.
2023-07-26 05:39:25.218 LOGSessionId: 6260139
Browser: unknown: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/114.0.0.0 Safari/537.36
GPU-Vendor: Google Inc. (Google)
GPU-Renderer: ANGLE (Google, Vulkan 1.3.0 (SwiftShader Device (Subzero) (0x0000C0DE)), SwiftShader driver)
2023-07-26 05:39:28.032 LOGnavigator.mediaDevices support available
2023-07-26 05:42:24.658 ERRORFailed to download file https://cdn.slashkey.com/flash/farm/...ild517.data.gz
2023-07-26 05:42:25.913 ERRORwasm streaming compile failed: TypeError: Could not download wasm module
2023-07-26 05:42:25.914 WARNWebAssembly streaming compilation failed! This can happen for example if "Content-Encoding" HTTP header is incorrectly enabled on the server for file https://cdn.slashkey.com/flash/farm/...ild517.wasm.gz, but the file is not pre-compressed on disk (or vice versa). Check the Network tab in browser Devtools to debug server header configuration.
2023-07-26 05:42:25.916 ERRORfalling back to ArrayBuffer instantiation
Game is VERY slow to load this morning.
Hi LisaScobee,
What was it that that you were doing in the game when you got the errors?
It looks like hardware acceleration temporarily disabled.
Please make sure that you have checked for and done any computer and browser updates.
Turn off all your show items in your game preferences, clear the browser if you have not done it recently, then close your browser for a coupe of minutes and reopen it and see if that improves things for you.
Please note that when you do browser clearing, you may be logged out of the website and that the first load what you show in preferences in game will be slower while you get a fresh load of graphics.
Old Jul 26 2023, 07:40 AM
Question
Would having my ISP Help Desk "reset" my connection stop these types of errors? I did that a bit ago but haven't been back to the game to see if it helped. ETA: Just logged back into the game and it was initially slow to load up but no error messages.
Hi LisaScobee,
Old Jul 26 2023, 08:17 AM
Hi LisaScobee,
If the errors are now gone it's likely that what happened was the hardware acceleration disabled for some reason. Try just closing the browser and reopening it if it happens again as that may be all you need to do.
If your computer meets the minimum requirements to play and your farms are not very large and layered that's not likely to be the cause. Heavy farms can be slow to load or work on devices that are only meeting the minimum requirements.
Slow connections or any slowdown in a link between your computer and the route it decides to use at that time, to get to the game servers can also cause a slow down. That's not something any of us can control or pin down exactly where the problem is. If it was that then it requires the company that owns the link with the issue to see it and then fix it.
You might want to try shutting down your computer and then also turning off your router/modem for a few minutes then turn it back on. When the router/modem has finished rebooting, turn your computer back on and try the game again.
The reason we occasionally suggest people try this, is that sometimes routers/modems can hang on to data which can slow things down.
Shutting them down for a few minutes gives it time to clear that out.
It's not something you would need to do at all often. Give that a try and see if that helps with your slowdowns. If it does not and it's not going to cost you any money then you could ask your ISP to check the connection to you and perform whatever tests they want to check everything is fine their end.
What they can not do for you is check every connection possible between your computer and wherever you are going on the web regardless if it's the game or another website as they won't own them all.
Old Jul 27 2023, 09:32 PM
Clohar Clohar is offline
Why am I getting that message with Chrome and with Firefox. It is the same desk top, same harware and software components except for the special in the browzer. How can I solve that problem. All cache mem cleaned game and browzer, history cleaned, registry cleaneed, windows updates cleared, browzer updated as well as windows. Here is the famous message:
2023-07-28 02:25:19.690 ERRORwasm streaming compile failed: CompileError: WebAssembly.instantiateStreaming(): section (code 10, "Code") extends past end of the module (length 45876493, remaining bytes 23921521) @+1027628
2023-07-28 02:25:19.691 WARNWebAssembly streaming compilation failed! This can happen for example if "Content-Encoding" HTTP header is incorrectly enabled on the server for file https://cdn.slashkey.com/flash/farm/...ild517.wasm.gz, but the file is not pre-compressed on disk (or vice versa). Check the Network tab in browser Devtools to debug server header configuration.
2023-07-28 02:25:19.692 ERRORfalling back to ArrayBuffer instantiation
2023-07-28 02:25:19.800 ERRORfailed to asynchronously prepare wasm: CompileError: WebAssembly.instantiate(): section (code 10, "Code") extends past end of the module (length 45876493, remaining bytes 23921521) @+1027628
2023-07-28 02:25:19.801 LOG{}
2023-07-28 02:25:19.802 ERROR{}
2023-07-28 02:25:43.836 LOGnavigator.mediaDevices support available
USER ID number is: 1593240078 Build No: 517
Adddict since early 2009
Old Jul 27 2023, 09:46 PM
Hi Clohar,
Are you seeing these on start up of your game or after you have been in and done some work there?
After you updated your browsers and Windows did you restart your computer?
Try shutting down your modem for a couple minutes and then back on. Those can hold data and may be holding something that is wrong.
If that doesn't work try the rest of the suggestions in the first post of this thread including the ones in the link there.
Old Jul 27 2023, 11:47 PM
Millions thanks Taz problem solved after several tries.
Old Jul 28 2023, 07:50 PM
jerry63925 jerry63925 is offline
getting all types error junk it will not load
Hi Clohar,
this si what i am gettibg
Old Jul 28 2023, 07:58 PM
Hi Jerry,
First make sure your browsers and computer system are updated. If you do have to do updates then be sure to restart your computer after you do those.
If that doesn't work please try all the Suggestions in the first post of this thread including those in the link in that post.
Old Jul 29 2023, 08:36 AM
dave1949 dave1949 is offline
Game not loading just white screen
In the meantime farm town is up again
is slashkey website down? I can't login, no matter what browser I use.
Always busy with something.
Last edited by Palmarina; Jul 29 2023 at 09:22 AM. Reason: problem solved in the meantime
