  #911
Old Apr 01 2023, 08:17 PM
Originally Posted by penguin66 View Post
I have lots of facilities at over 100% production. As of right now, they are:
Brewery on F4, F9, and F26 at 104.9%
Cinnamon Factory on F2, F4, and F6 at 104.9%
Food Preserve Factory on F2, F10, and F38 at 104.9%
Juice Factory on F2, F39, F41, and F42 at 104.9%
Oast and Malt House on F2, F3, F5, and F10 at 104.9%
Oil Refinery on F2, F5, F9, F10, F11, F12, F13, F14, F16, F17, F20, F22, F23, and F25 at 104.9%
Petrochemical Plant on F2, F3, F6, F10, F12, F13, F14, F16, F17, F20, F22, and F30 at 104.9%
Smokehouse on F2, F4, F9, F10, F12, and F16 at 104.9%
Spice Factory on F2, F30, and F42 at 104.9%
Turbo Petrochemical Plant on F42 at 104.9%
Winery on F1, F2, F9, F10, F12, F36, and F38 at 104.9%
Wine Cellar on F9 and F12 at 104.5%
Dairy Processing Plant on F1, F2, F3, F4, F5, F10, F11, F12, F20, F25, F26, F29, F32, F34, F35, F36, F37, F38, F39, F41, and F42 at 104.5%
Bakery on F1, F2, F3, F10, F12, F14, F20, F21, F25, F29, F39, F41, F42, and F43 at 104.4%
Chocolate Factory on F2 and F4 at 104.4%
Coffee Grinder on F2 and F25 at 104.4%
Construction Materials Factory on F2, F4, F10, F11, F20, F21, and F22 at 104.4%
Distillery on F2, F4, F9, and F10 at 104.4%
Drying Facility on F2, F4, F10, F39, F41, F42, F43, and F44 at 104.4%
Electronic Component Factory on F4, F10, and F21 at 104.4%
Essential Oils Plant on F2, F4, and F10 at 104.4%
Food Coloring Factory on F11 at 104.4%
Food Flavoring Factory on F20 at 104.4%
Food Ingredients Factory on F2 and F26 at 104.4%
Glass Factory on F2, F4, and F10 at 104.4%
Ink and Pigments Factory on F2, F4, F10, F12, F38, F39, F41, and F42 at 104.4%
Metal Mill on F1, F2, F4, F5, F9, F10, F11, F12, F16, F25, F26, F29, F32, F35, and F36 at 104.4%
Oil Factory on F2, F4, F14, F30, and F38 at 104.4%
Paper Mill on F2, F4, F10, F12, F16, F20, F25, F35, and F36 at 104.4%
Pasta Factory on F2, F10, and F43 at 104.4%
Plant Milk Factory on F2, F4, F10, and F14 at 104.4%
Red Windmill on F1, F3, F4, F10, F25, F34, F35, F36, F38, F42, and F43 at 104.4%
Rubber Factory on F1, F2, F4, F5, F10, F11, F12, F16, F20, F25, F29, and f32 at 104.4%
Sauce and Condiments Factory on F14 and F42 104.4%
Sawmill on F2, F4, F5, F9, F10, F11, F12, F13, F16, F25, F34, and F36 at 104.4%
Stone Windmill on F1, F3, and F21 at 104.4%
Sugar Refinery on F2, F3, F4, F5, F6, F10, F11, F12, F16, F25, F37, F38, F39, F41, and F42 at 104.4%
Tea Factory on F2, F10, F25, F39, F41, and F42 at 104.4%
Textile and Spinning Mill on F2, F4, F5, F9, F10, F11, F12, F16, F20, and F21 at 104.4%
Turbo Bakery on F21 at 104.4%
Turbo Oil Factory on F21 at 104.4%
Turbo Sugar Refinery on F21 at 104.4%
Turbo Textile and Spinning Mill on F21 at 104.4%
Watermill on F1, F2, F4, F9, F10, F21, and F25 at 104.4%
All other facilities are at 100% or less right now.
Thanks in advance for help!
Hi penguin
Thanks for your list
Those facilities are the ones which would be increased in 10% as you purchased farm pass. But at this moment you have 59 points and that reward for increasing capacity 10% for facilities producing common ingredients is available when you get 75 points, so not sure what is happening there.
Please contact Support. To contact them click on the link below, fill out the form and submit it. Please include all details about your problem so you can get help faster. Be patient as it can take anywhere from a few hours to a few days for them to respond to you depending on how many tickets they have ahead of yours.
If you do not get the automatic response then please read the following link:
Old Apr 01 2023, 08:48 PM
penguin66 penguin66 is offline
Thank you!
Edit: I received a reply back from support and wanted to update you with their response. I had farm pass last month and had enough points to increase the capacity for facilities producing common ingredients by 10%. When the new month and new farm pass started, I hadn't reached the number of points required for the added 10% so my percent utilization was at over 100% and remained over 100% until I used enough ingredients to drop the utilization below 100%. Everything is below 100% today and I was able to load items correctly. I hope my explanation makes sense. Thanks again for your help!
Hi penguin
Old Apr 02 2023, 02:41 PM
Thank you!
Thank you for letting us know penguin
Old Apr 02 2023, 07:18 PM
Gary V Deutschmann Sr Gary V Deutschmann Sr is offline
It appears my Lanolin Factories have not been loading. I tried to do it manually and it gave the pop-up to request stock from neighbors. Says it needs 240 to start, and I have over 2400 in inventory storage.
Old Apr 02 2023, 08:28 PM
Hi Gary
I moved your post to the thread about Facilities and Facility Manager.
The Lanolin Factory uses Sheep Wool but that item is also used in other facilities, so 2,400 sheep wool stored could be not enough to fill all facilities using it.
Just let me give you an example: you have 9 Textile and Spinning Mill. Each of them uses 810 sheep wool to fill to 100% so only to fill all 9 factories to 100% you need 7,290 sheep wool and you only have 2,400 stored.
The best thing you can do, is to open your Facility manager and then click in the little notebook. That is the ingredient planner.
You can set it to All Facilities, 15 days (that means you can fill your facilities to 100%) and By Missing.
Then check if Sheep wool item has red number into brackets. If so, that means you do not have enough stored to fill all your facilities using sheep wool.
You can find information about the ingredient planner in the following link from our Game Guide:
http://r1.slashkey.com/forum/showthr...22#post6298322
Old Apr 06 2023, 09:53 AM
Janice Ligon Janice Ligon is offline
Default Can not post Facs.
I need to know how to get Facility Filter off my Farms. I am unable to post my facs.
Old Apr 06 2023, 09:56 AM
Hi Janice
We moved your post to the thread for your problem.
Which facility are you using to try to post?
What happens when you try to post? What you see in the screen?
Also, try the following:
Please open your Facility Manger and click on the Funnel Icon top right of the window that opens, then make sure that it is set like this for your facility tools to work on all facilities on all farms. Please remember to click the green check mark to save any changes.
Old Apr 06 2023, 02:44 PM
Default Facilities and Facility Manager
It stays on current farm. I change it to all farms then will not accept green check. I have tried several facs none will open.
Old Apr 06 2023, 02:51 PM
Hi Janice
The filters have to be for All Facilities in Facility Status, All Farms in Facility Location and then Regular Facilities All and Service Facilities All. Then you have to click in the green check mark to save changes.
Are you loading your farms from a saved link in your computer? If so, please do not do that as it could be corrupted.
Instead, load Facebook and then click in the game icon in the left column in your Facebook home page. See if that way the facilities work for you.
Also, clear your memcache, link below. A new window will open with a short list of unsettings. Close that window and your farm in all tabs you have it open. Then reload the game and try to post again.
If nothing works for you, check that your browser and computer system are up to date
After any update it is always better to restart your computer.
Old Apr 07 2023, 09:31 AM
I have done everything I have been instructed to do and can not open to post my facs. It is sad. I have played since the beginning. This is no longer fun.
