  #181
Old May 12 2021, 04:02 PM
Originally Posted by bbarksda View Post
In the previous version, when we selected a crop to plant it would default back to that crop to select when working the next farm. Please make it where it defaults back to the crop that we planted on the previous farm. The way it is now, it is easy to select the wrong crop than intended. Thanks for your help.
Hi bbarksda,
If you want to make a suggestion please post it in the Suggestions section.
Old May 17 2021, 06:05 PM
jcloud5078 jcloud5078 is offline
i always stack 4 fields that i use for crops and then on top of that i stack 2 more fields for trees or flowers......... the problem i am encountering is that now when i do this the trees or flowers are fine but the stack fields are intermittant.......... some show only a few crops but always big empty spaces where there should be crops but there are none..... i have 4 farms that are like this? how can i fix this?
Old May 17 2021, 06:13 PM
Originally Posted by jcloud5078 View Post
100000009499222
Hi Jcloud,
You were already answered about this for you post in the Game Migration Updates thread.
Here is a link to the answer:
http://www.slashkey.com/forum/showpo...postcount=4073
When you can't find your posts try the instructions in the following link:
http://www.slashkey.com/forum/showthread.php?t=594766
The answer to your posts will be 1 or 2 posts below yours.
Old May 21 2021, 12:49 AM
JoAnne07 JoAnne07 is offline
Cool Plowing (over trees)
I have not been able to plow (after I extended my farm 14) for over a month now. It will accept plowing over the new section but not the old.
COULD SOMEONE PLEASE HELP BY TELLING ME HOW TO DO THIS?
[Mod edit: layering instructions removed]
Last edited by Tiger; May 21 2021 at 04:28 AM. Reason: removing layering instructions
Old May 21 2021, 04:28 AM
Hi JOAnne07,
I have moved your post to the thread about plowing.
I'm sorry but what you are describing is layering. Layering can and has caused problems so we are not permitted to give or let anyone provide instructions for which layering methods may or may not be working at this time. We are aware that not all previous methods are working, we do not know if they will all work in the future.
Old May 28 2021, 06:32 PM
anjovi6 anjovi6 is offline
Default plowing
USER ID 1209095773
With the new update and the addition of farm 44, after planting trees and adding about 15 facilities I cannot plow the farm. tried several different ways with no luck.
Old May 28 2021, 06:38 PM
Originally Posted by anjovi6 View Post
USER ID 1209095773
Hi anjovi6
If you are trying to plow under those items, then that is a trick and neither us nor other users are allowed to give instructions on the forum.
Old May 28 2021, 07:27 PM
Cynthia Shear Cynthia Shear is offline
Default can not chop or harvest my ready trees
Any help with this will be appreciated.
Old May 28 2021, 07:35 PM
Hi Cynthia Shear,
I moved your post to the subject thread about harvesting.
What happens when you try to do so?
If those trees have just become ready please try refreshing the farm. I don't see any of the log trucks or tree shaker tools in your account so the only tools you have that will do those are the axe and the swing blade.
Old May 29 2021, 05:37 AM
If i remove all the trees and facilities and the plow the farm will I be able to add facilities and trees like all my other farms
