  #111
Old Mar 22 2013, 01:52 PM
LibrarianLee LibrarianLee is offline
Default Sprinkler
Same with my green sprinkler. It's in my storage, but not available on the tools menu.
  #112
Old Mar 22 2013, 01:54 PM
Hi,
The developers are aware of the sprinkler issues and are looking for a fix.
In the meantime you can take the sprinkler out of storage and place it on the farm to use or if you have a bit of patience there is a method you can try but it does take a bit of fiddling about.........
In the extended toolbox, hover over the sprinkler around the midpoint and slowly move the cursor towards the top, you will see the box shift upwards, by a tiny amount, when it does that click on it and you should grab the upgraded sprinkler to use.
  #113
Old Mar 22 2013, 01:55 PM
Nelly Green Nelly Green is offline
Default vanishing sprinklers...
Thank- you, Thank-you for the update, but now my sprinklers are also gone, as so are their functions, i.e., shorter growing times
further it no longer says my farms are irrigated after using them.
I hope this gets fixed quickly. Thanks!
  #114
Old Mar 22 2013, 01:56 PM
Default Turbo Tools
I was very happy with the addition of the Turbo Tools for the Service Facilities, loaded them this morning and was so much quicker. However, I have just reloaded my facilities, click on the 'Load All' button first, then loaded up the other facilities, was not really concentrating and realised I had gotten down to the Service Facilities, and without exception I could load each one up individually to a much higher % than they had been loaded by the tool, some were loaded at 40% and when I clicked individually they went to 100% ??? I will keep a watch on this for the next couple of times I load them. I would have assumed that the Turbo Tools would load them as much as was possible with the stocks available???
  #115
Old Mar 22 2013, 01:59 PM
gsmattingly gsmattingly is offline
Where can I find the current Levels and their associated/necessary Experience Points?
Also does the Experience Points display have a limit on the number of digits displayed?
I'm at level 400 and I see neighbors in the little display at the bottom who seem to have fewer experience points than I do but are, say, at level 385. Or is it possible that I am missing a digit in my display. I see
25047630
Is that 25,047,630 or is it
250,476,30?
I'm a little confused since I haven't been paying much attention to it.
Gary
  #116
Old Mar 22 2013, 02:03 PM
beverduster's Avatar
amazing, just simpley amazing, now i can't water my crops
  #117
dorissau dorissau is offline
Originally Posted by FarmerMcLashwood View Post
Thanks for the update but it would appear I and many others are having problems with the mobile sprinklers. Although I have all the mobile sprinklers in storage only the flower sprinkler is showing. I have taken all sprinklers out and put them on farm.... saved then refreshed..... put them all back in storage, saved and refreshed....... and still they are not showing up. Need them to be working. Am sure Devs will be looking into this. Just thought I should report the problem in case they were not aware."
sprinklers are very confusing.. I do not dare sprinkle my flowers in case it irrigates a farm I don't want accelerated. I think I need a better explanation of the functions.. including that reference to only watering flowers on a 32X32 expansion.
  #118
Old Mar 22 2013, 02:04 PM
25047630
250,476,30?
Gary
The new levels have not been released yet. They are coming in the next 5 to 10 days.
  #119
Old Mar 22 2013, 02:24 PM
shutterhunter shutterhunter is offline
Hey Gang, I just took out my sprinkler out of storage, placed it on a farm, clicked on it and selected "Irrigate" then proceeded to just go from farm to farm watering as I went. It seemed to have worked. Just planted Oat fields saying done in 1.2 days instead of 3.
  #120
Old Mar 22 2013, 02:30 PM
Which sprinkler are you confused by? If you have the purple one, when you use it the menu that pops up has two tabs, which let you choose one farm or multiple farms.
The brown/grey one only does flowers , nothing else.
There was a problem watering flowers planted in the 32x32 expansion. That's what has been fixed with this update.
