  #551
Old May 14 2022, 08:18 PM
Swiffer Swiffer is offline
Default disconnected from server constantly
I can't even go and read a pm quickly come back and I'm disconnected from the server can't even click on the Green Tick to reconnect I have to go open a whole New FT,,, been doing this for 2 days now,
also when working others Facilities I can only work e.g. the Clients ,,, wait them out then work the Reg Facilities for that person,, and it takes so long to go thru the whole ordeal about getting on the Tracker etc etc. Before the change over I used to be able to work 8 - 10 peoples Facilities and clients at once and not have to go through all that Bologna ,,,, too time consuming
Sorry to complain but I wouldn't have much of a Life outside of FT if I worked my Friends Facilites etc
Lynda Diotte Swiffer
Old May 14 2022, 08:54 PM
Hi Swiffer
I moved your post to the thread for your problem. Please follow all suggestions given in the first post, first page of this thread, including the ones in the links.
Old May 14 2022, 11:39 PM
Elizabeth5's Avatar
Elizabeth5 Elizabeth5 is offline
Hi Elizabeth
Please clear your browser cache. Take in mind that the first time you load the game after the clearing, it will load slowly as all graphics have to be loaded.
I've done that more than 100 times n it's still like that. That's why this needs Raul's help. I think this is more of technical problem than a simple thing. Thanks Marcela
http://apps.facebook.com/farmtown/?farm_id=1037566667
Server ID: WF 37
Old May 14 2022, 11:45 PM
Hi Elizabeth
Is this happening in all browsers you tried? Asking this as clearing browser cache is what is suggested for this kind of oroblem.
You have more suggestions to try in the first post, first page of this thread.
If nothing works for uou, then please contact Support.
Old May 15 2022, 05:34 AM
Elizabeth5's Avatar
Hi Elizabeth
Yes Marcela, I've tried in all the browser that I've tried except for my mobile phone. I tried on Google Chrome, Opera and Edge. Nothing works. I'll contact support. Thanks so much for your suggestions.
Server ID: WF 37
Old May 15 2022, 08:13 AM
Hi Elizabeth
Are you sure you cleared your browser cache? I had a look at your data and it shows you have cleared your memcache lot of times, but it doesnt work for the problem you describe.
Also check if you have any pending update for Windows or Mac in case you use it.
Old May 17 2022, 07:55 AM
Qivis Qivis is offline
I have been trying to open Farm Town for another account, but Facebook is not showing the usual lists under Settings Blocking. Instead it is showing a list of different ways to MANAGE blocking and unblocking Farm Town or any other app is not possible because it will not acknowledge that Farm Town exists. If I use my browser bookmark or any other usual way to open the game it is instantly blocked because I set it to way back on July 20, 2018. I cannot get Facebook to list the apps that I have blocked in a way that I can unblock them. I can only list them. It even blocks the link to try to clear the Farm Town memcache because of this. Facebook is not showing the normal page for blocking and unblocking people, apps, etc in my main account either!
Friends don't let friends boot from hard drives! A real friend would recommend an SSD. Or better yet NVME.
Last edited by Qivis; May 17 2022 at 08:04 AM. Reason: It is not just another account that has the problem
Old May 17 2022, 08:25 AM
Hi Qivis
It seems Facebook has changed the way to see any blocked app.
But you can click in Add to your list of blocked apps link and start typing Farm town. See if you see the Unblock button to the right.
Also, in the Block apps information you have a link for More information.
If nothing helps you, then you will have to contact Facebook and see if they can help you.
Old May 20 2022, 02:14 AM
mandy_tew mandy_tew is offline
Default not workin says bug
can anyone help i keep getting this 2022-05-20 07:13:13.070 ERRORApplying workaround to Firefox bug https://bugzilla.mozilla.org/show_bug.cgi?id=1397977 and it will not load on any browsers
Old May 20 2022, 04:43 AM
Hi mandy_tew,
I have moved your post to the thread about loading issues.
What were you doing on your farms prior to getting this problem?
I have had no problems loading your farms.
The error you are seeing in Firefox has been there quite some time and will not be what is causing you a loading problem in Firefox.
Various browsers have had updates recently, have you checked for those yet? If not please do so and also check for any computer updates and do those if showing as well.
Please remember to close your browser then reopen it after updating them.
Then see if you can load your farms.
There is more information in the first post on page one you can also try if you still can't load your farms after that.
cannot load game, dotween, farm not loading, farm town not loading, frequent crashes, game freezes, green screen, loading issues, saving data, settweenscapacity, u00, webgl, white screen, x025, x025 error
