Old Mar 25 2013, 08:27 PM
Arrow Tools and Fuel
This thread is for reporting problems concerning any of the Tools you can buy in Farm Town or any issues with Fuel.
Please read the following information BEFORE posting in this thread. Thank you!
Check Out The Game Guide:
Chapter 02 - What is the Tool Box? - Basic guide to the icons in the tool box with links to explain what those are for.
Chapter 20: Fuel Everything you need to know about fuel is included here.
Chapter 21: Tools Everything you need to know about tools is included here.
It is now possible to have more than 4 Billion fuel.
As of May 2020 you can now top up your fuel, it no longer gets replaced when you refuel.
Important Things To Remember About The Tools You Own:
  1. Any of the Farm Cash tools for harvesting (crops, trees, flowers), plowing, chopping, fishing can be used to work on other peoples farms, including the 3x3 coin tools. These tools MUST be in storage for this to work. The bigger tools will use fuel.
  2. Once your tools are in your Item Storage, you can use them via your Yellow Toolbox, there isn't any need to take them out of storage.
  3. Farm Cash tools do NOT use up any of your Item capacity space.
Important Things To Remember About Fuel
You only will be able to refuel once per day. You will be able to refuel again after midnight Eastern time.
If you have already refuelled that day and you want to know when you can next refuel, click on the fuel station icon again and if you have to wait, there will be a time showing at the bottom of the pop-up. For example it could say "You will be able to refuel in 5 hours and twenty minutes"
If it seems you are using fuel quicker than expected. You could be using more fuel due to some of these:
  • Buying Land Upgrades/New Farms and adding more workable items that require Fuel to work them.
  • Increasing what is on existing farms that require Fuel to work them.
  • Working your own farms. Farming and Planting more often - perhaps on days where more work is ready to do than there is on another day or on days when you require the short timed crops so will be planting more often
  • Working for other farmers, the bigger the farms, the more on them, the more fuel you will need if you are using your own fuel to work those.
  • The more facilities you have, using the start All tools and refilling them more often will use more fuel.
    Using the Start All at the top of the Facility Manager uses Fuel (turbo tools)
    Using the Store All at the top of the Facility Manager uses Fuel (Forklifts)
    Cashing out uses Fuel (Armored Truck, Farm Cash Item not the decoration) Unless your Harvests & Products is getting full or you need the coins, you do not need to cash out every day. Remember you can zip your Harvests & Products storage to help if your capacity limit is getting full.
  • Dispatching Trains and Ships uses fuel. The more containers on them, the more you use.
  • Fuel is sold in the Gas Station service facility. It does NOT give you more fuel tanks. If you are low on fuel, do not load it into that facility. If you own the load tool for that facility, you open the facility and remove the check mark on the Fuel Tanks so it's not loaded into it to be sold.
The Difference between sending friends Bonuses of Fuel Tanks OR sending Ingredients to make Fuel Tanks
A common mistake is not reading the information in a request to know if you're going to be sending and receiving Fuel Tanks or if you are instead sending and receiving the ingredient crude oil which is need to make Fuel Tanks.
Both requesting Ingredients to make Fuel Tank and a request to send a Bonus of Fuel Tanks have the same Fuel tank Icon.
Read the information to the right of the icon!
When it tells you:
"Can you send me ingredients to make 68 x Fuel Tank (4 batches)? YOU will get 50%!" and the link says Send Ingredients, you are sending and receiving the ingredient to make the Fuel Tanks which is Crude Oil.
When it tells you a bonus or dan has been earned:
"I just reached the Fuel Tank Black Belt! Help me claim a 278 x Fuel Tank Bonus and YOU will get 50%" and the link says Get Bonus, that's when you send and receive Fuel Tanks instead of Crude Oil!
The limits for sending/receiving bonuses are listed in Chapter 30 Belts/Dans:
https://r1.slashkey.com/forum/showth...78#post5224278
Missing a tool? Please read the first post HERE
For Suggestions for Tools post in Machinery/tools both functional and non-functional
