  #2051
Old Feb 21 2021, 06:43 PM
pflute pflute is offline
Red face XPs not showing up
XPs are not populating when I sow/plant on SN farms....before the 2/19 update they were. My user ID is 610920035
Thanks for working so hard on this. It is MUCH appreciated!!!!!!
  #2052
Old Feb 21 2021, 06:56 PM
Hi pflute,
That would be because the work is not being done. The seeders are not working for super neighbor work currently. If your neighbor has a combine for harvest plow plant or you have one those do work. The developers are aware of this and looking into it to fix it.
  #2053
Old Feb 21 2021, 07:37 PM
bullish bullish is offline
Default stuck
acci. # 1502811032
can only harvest, plow and plant crops. Nothing else on my farms. no trees no flowers no structures. also coins and xp stay the same. no way to work toward advancing. cannot leave my farms.
  #2054
Old Feb 21 2021, 07:40 PM
Originally Posted by bullish View Post
acci. # 1502811032
Hi Bullish,
How are you getting into your farms? If you are using a saved link then please don't because that will not get you to the current version.
You need to either use the shortcut on your Facebook home page or the Play FarmTown button at the top of the forums.
  #2055
Old Feb 21 2021, 09:25 PM
PQbluebonnet PQbluebonnet is offline
User ID 1405735222
My Farm 39 which has lakes, has not loaded properly since the conversion. Toggles between green and black screen. I would appreciate any and all help if possible.
Thank you for your time.
Alma York, PQbluebonnet
  #2056
Old Feb 21 2021, 09:26 PM
loudnsassymommaCollar loudnsassymommaCollar is offline
Are you saying I don't have to work as an sn for 5 people because my experience will never get higher? **** my experience is so low newbie farmers are higher than I am.
How do I get to use my tools on other farms I am an sn for?
  #2057
Old Feb 21 2021, 09:30 PM
Originally Posted by PQbluebonnet View Post
User ID 1405735222
Hi Alma,
I tried to load it too and it would not open. I will try doing a data clean of that farm and see if that will help. You will need to close your farms and reopen them for it to take effect.
  #2058
Old Feb 21 2021, 10:29 PM
Originally Posted by loudnsassymommaCollar View Post
Hi loudnsassymommaCollar,
No, I did not say your experience points will not get higher. As you work or buy things or do your facilities then you will receive more experence points. That is the number above the white bar at the top of your farm. What I said was your level in the green oval to the right of the bar will not go up until the developers add more levels. When they do add levels then you will jump up to the level for the amount of experience points you have earned or to the top level again if you have more than is needed for that level. Your current experience points are 1,544,142,783 Which is way over what is needed for the level 1200.
Your tools and the neighbors tools are shown in the Toolbox together. What tool are you wanting to use that they do not have and you do have?
  #2059
Old Feb 22 2021, 12:40 AM
soccerguy3 soccerguy3 is offline
My user Id is 1297551737 and I am the SN to one of my neighbor's whose user Id is 100003893069053. While he was loading his facilities in the facility manager, he noticed that while he had plenty of resources for mutliple Metal Mills, he needed to add more to his farms. Since I had a purple hand and he didn't, he asked my to use design mode and buy him a Metal Mill and put it on his 9th farm. After doing this for him, I went back to my farm and ran my Facility Manager and noticed that I had a Metal Mill listed on my 9th farm (which I exclusively use for clients, not factories). Going to my 9th farm and using the search tool, it returns nothing found when I look for a Metal Mill. My neighbor can see it on his farm 9. If he selects it and clicks Start ALL it will fill each item to 100%. When he launches his Facility Manager he can not see it.
  #2060
Old Feb 22 2021, 04:31 AM
al_bundy's Avatar
al_bundy al_bundy is offline
when you click to harvest the stables it doesent reset from ready to harvest to the amount of time untill next harvest untill you reload the facility manager only affects the stables
Click HERE For instructions on clearing your browser's cache
Click HERE To clear your macromedia cache files
Click HERE For instructions on linking your farm to the forum
