#181
Ive just had a look at the Neighbour chain rankings, The top of the pile have 260k points, the chain Im in have 90k. That does not appear to me to be equal chains. Yes pls opt out option.
#182
"b) Of the 2 FarmCash facilities selected each week, you can have as many as you own participating in the contest."
i own 6 dairy processing plants(farmcash facilities). but only 1 is being counted in the contest? |
#183
Farmcash facilities are those when buying u pay by farmcash
#184
![]() Quote:
![]() I'm sorry but the dairy processing plant is a coin facility. It costs 80,000 coins
#185
Thanks for fix on my boat yard ....now I see the NUTRITIONAL SUPPLEMENT STORE IS ALSO NOT WORKING...didn't think I had it, decided to check and saw that I did have it.....Thanks it is on farm 21
#186
![]() Quote:
I moved you post to the New Release as it is related to that and the devs wish to see any problems with it posted here. I have checked your data. You do not have a Nutritional Supplement Store, you do have a Nutritional Supplies Factory.
Tiger Clickable Help Links:
#187
really need to explain these neighbour hood chain contest more clearly no one has a clue what to do or who is on your chain... it is so confusing and also get the fc gifting re activated
#188
This may be a stupid question, but the dairy fac I have several but it only shows on on the new quest game, how do I make it see I have multiples of that factory?
#189
![]() Quote:
The amount of facilities you can have in the contest are based on these rules >> If you have none of the FC facilities for the contest then you can only use 1 of each of the coin facilities. If you have 1 of each of the FC facilities, then you can still only use 1 of each of the coin facilities. If you have more than 1 of the FC facilities, you can use those plus an equal number of coin facilities. For example, if you have 3 of the 2 FC facilities then you can use 3 of the coin facilities. You can only use as many coin facilities as you have FC facilities.
#190
I see my neighborhood team, how do I know who is in it?
Can someone NOT be selected for a team? How often do the rankings change? Is there an advantage to working my 6 facilities more than twice a day? Why does someone with 4 facilities in play have over 174K points and I with 6 have 11K? Is there a discussion group thread for everyone to join? Thank you. |
