  #1401
Old Jun 23 2024, 06:48 PM
Originally Posted by NJones277 View Post
OK - please excuse me for using the wrong terms - I meant Start All. I had a Feed Supplement Facility unchecked when I did a Start All and it started everything. It was down to about 5% when I Started All. Now it's over 95% and I still have it unchecked. I was inquiring about this specific facility. I've done the same thing with the non-workables and they don't load. Nor do the regular and service facilities. Just this one. I just wondered if this is a "feature" or a bug.
Hi NJones,
No it is not a feature nor a bug as I tried it and the one I unchecked didn't add any more to what was pending. We can't duplicate what you are saying. Where are you looking to see the 5 and 95%?
Old Jun 23 2024, 08:23 PM
Before I did a Start All this afternoon, I checked to make sure one of the Feed Supplement Facilities was unchecked. At that time it had only about 5% production. So I did a start all and it filled up. Now, after several hours, they're at about 95%. Looking in the Facility Manager. I usually only do a Start All once a week. Otherwise, I keep the NCC facilities and services full. And get as much production out of the Premium Fodder as I can. I'm trying to build up my inventories on crops, as I just recently redesigned all my farms.
Old Jun 23 2024, 09:16 PM
Hi NJones,
I am not sure I understand as the Feed Supplement does not use crops to produce. It uses coins. Which tab are you looking at that you see the 95% production?
It is possible you have reached the maximum facilities/products that you can uncheck. If that has happened then unchecking another facility will not work. You might have to either check a couple facilites so they can produce or if some are empty of production then put those in your storage and then see if that stops adding production in the Feed Supplement Plant you unchecked.
Old Jun 23 2024, 09:24 PM
Yes I know the Feed Supplement uses coins. I don't do a full "start all" but once a week, on Sunday, so that other facilities that use crops give me a chance to restock. Still working on the formula that allows me to do a full listing more often.
I only have the one Feed Supplement unchecked. Everything else is checked.
Old Jun 23 2024, 10:02 PM
Hi NJones,
So you have no other facilities or products unchecked?
The limit is not by facility type, but is all facilities and products you have unchecked.
If that is the case then you will need to contact Support as we can not duplicate this.
Old Jun 23 2024, 10:40 PM
No - just one of the Feed Supplement Facilities. Everything else is checked - facilities, services, non-workables and all products in all of these.
Old Jun 23 2024, 10:51 PM
Hi NJones,
Then you will need to contact Support as we can not duplicate this.
Old Jun 23 2024, 10:54 PM
Thanks Taz - sorry things were unclear.
Old Jun 28 2024, 06:37 PM
Lessonlady Lessonlady is offline
Send a message via AIM to Lessonlady Send a message via Yahoo to Lessonlady
Default Premium supplies
How can I get more Cow Hay, Poultry mix, and Silage for Sheep and Llamas? Do I need to buy more facilities?
Old Jun 28 2024, 06:47 PM
Hi Lessonlady
Those items are produced in the Fodder factory which is a coin facility so you can buy more if needed.
You can also ask for ingredients for the items produced in the Premium fodder factory once a day.
You will also receive ingredients when you click in your friends requests for premium fodders in the Other wall requests.
