  #1111
Old Nov 01 2024, 01:48 AM
Question Previous Farrm Pass
I didn't get the chance to earn all the Farm Pass rewards (the buildings) before the end of the month. Is there a way to do that now? If not, please suggest to the devs that they add those items to the store the next month after the Farm Pass.
USER ID number is: 1637121091 Build No: 645
Visit my farm!
Old Nov 01 2024, 07:21 AM
Hi Lisa
No, that is not possible.
You can suggest this yourself using the Suggestions section.
You can't start a new thread there but you can post in a thread that fits with your idea.
This is the link to Suggestions section where you will find an open thread for Farm Pass ideas:
https://www.slashkey.com/forum/forumdisplay.php?f=2
Old Nov 04 2024, 07:14 AM
Pegasus_III Pegasus_III is offline
Good morning! The farm pass this morning has "Water 21 Lotus using the watering can" as a daily goal. I did not have any lotus on my quest farm (23). I added 30 Lotus to the farm and then watered them with the watering can. The Farm Pass did not register the fact that I watered 30 as completing the daily goal. Thoughts?
Old Nov 04 2024, 07:25 AM
Hi Pegasus
When you buy flowers and place them on your farms they are already fully watered.
If you hover your mouse on the flowers you can see all blue drops which means they are watered.
If you are superneighbor for someone who allowed you to do their flowers, then see if they have lotus and they need water.
Old Nov 04 2024, 08:36 AM
Hi Mary. The fully watered does not show when I purchase the flowers. I watered them and then they showed fully watered. That said, I suspect the fact that the flowers come fully watered (but not showing) is the answer. I worked a neighbors farm for which I'm SN and the watering registered correctly. Thanks for posting the answer! Appreciate all you do!
Old Nov 04 2024, 12:02 PM
Hi Pegasus
I tested that before answering you just in case something had changed. But nop, as soon as you place a flower on the farm, it shows the fully drops.
So great you were able to complete your goal and thanks for letting us know
Old Nov 06 2024, 10:37 AM
tmoulder tmoulder is offline
Default Question about SP goals
If I have a Season Pass goal to work on other farmers facilities and they are a Super Neighbor and when I go to their farm to work their facilities I do not actually work the facility named in the Season Pass goal, rather the mayor works that particular facility for me I only get credit for working the facility once, however, If while I am there working the neighbor's facilities I actually work the facility named in the Season Pass goal myself I get credit for every product in the facility that I work -- normally it would be 8 (not 1).
Is this working as designed? I know that it is working as coded.
I think I should always get credit for every product in the facility that I work, whether it is actually me or the mayor that does the work. After all, I have no control over whether I actually work the facility or the mayor works the facility.
Tom Moulder
Old Nov 06 2024, 10:54 AM
Tom Moulder
Hi Tom,
I moved your post to the thread about the Farm Pass,
The seasonal goal for working the facility is the facility itself and you only get 1 regardless of how many products are in the facility.
Old Nov 06 2024, 02:33 PM
corogirl corogirl is offline
One of my goals is to load 25 toddler swings into the Playground Gear factory. I can't find this factory anywhere??
Old Nov 06 2024, 02:50 PM
Hi corogirl
You have 49 Playground Gear Factories.
Please go to any of your farms and click in the yellow tool box. You can put a check mark to Show Regular facilities option in your preferences, the wrench.
Then click in the magnifying glass. You will see a window to type the name of the factory you are looking for.
After typing the name, put a check mark to Hide non matching items. Then click in the green check mark.
farm pass, ingredient packs
