#91
![]() Quote:
I'm sure you are well aware that Slashkey has nothing to do with what criteria Facebook have set for what goes against their community standards. I am able to do exactly what you describe and not raise any of their automated flags that can trigger blocking, I've been doing that on and off all day, so I am assuming this isn't affecting everyone. It's possible that they may have changed something recently and that it hasn't rolled out to all Facebook accounts. If what they have done is causing you a problem you need to report that to Facebook. If you wish you can contact support and see what they says about this.
Tiger Clickable Help Links:
#92
Yes this second bit is what I was referring to. Thanks for the info.
so it goes, Denise https://apps.slashkey.com/farmtown/p..._id=1450953003 clear memcache https://apps.slashkey.com/farmtown/p...lear_memcached |
#93
![]() Quote:
***************************************** Friends don't let friends boot from hard drives! A real friend would recommend an SSD. Or better yet NVME. |
#94
![]() Quote:
There is no reason to bother Raul with this as there is nothing he can do about Facebook's security settings. The only thing I can suggest is don't try opening so many tabs at one time or so quickly. I open 4 - 6 at a time and do not have any problems doing the facs with those.
#95
saved the products from bird products facility, for some reason they won't load in to bird shop - trying to understand why they won't load
#96
![]() Quote:
If you are still having problems with this, the usual culprits to check for when you own the facility start/store/load tools are:
Need help? Post in Help and Support How to get and Create your Farm Link How to FIND YOUR POSTS on the forum. Last edited by Tiger; Jun 27 2021 at 06:18 AM. |
#97
I am watching a friends acct while they are not here. For the past 2 days when I go to her metal mills ands click on the plus sign, I get the first 2 or the 5 metals posted and when I go to post the 3rd, I get a message that I can only post 5 every 12 hours, yet I have only posted 2.
106722756337155 |
#98
![]() Quote:
I moived your post to the subject thread about facilities. You can check the Show Times to see how long beforee you can post ingredient requests. You either requested ingredients in another facilty or clicked to post but changed your mind and closed the pop up or possibkle clicked twice on one. Any of those will count whether you post it to Facebook or not. Edit: Go to the My Requests/Show Other Wall Requests from your own farms and see how many are showing there for her in the last 12 hours.
Taz Dubh Glais Estates Please come visit me on my farms (underlined link above) and if you see me say hi! I do ask that you not send me in-game messages for any problems other than forum login issues, as I can only help with those from my farm. Post your problem or question here in the forums and we will gladly help you to solve it as quickly as we can. Last edited by Taz D; Jun 27 2021 at 02:35 PM. |
#99
I purchased the new facilities, smartphone and Pakistan X2.
I went to look to see how many were needed for 3 months by name None of the items in those 2 x 2 facilities were in the list. Looked to see if they were in the Facility Manager. NO Went to the fields and found them. Filled them up manually and they showed it in the facility Manager and in the what the facilities require Do not know if I solved a problem but . . . |
#100
![]() Quote:
Yes that should have solved the problem. If they were not previously in the facility manager then when you checked the ingrediuent planner their products and ingredient needs would not be included. Once you fill ed them and they showed in the facility manager then you should be able to see the ingredient needs for those.
