#621
Game is NOT updating when I harvest and replant.
I ran memcache....twice. |
#622
![]() Quote:
![]() I moved your post to the thread for your problem. If you want data being updated, then you need to reload the game by clicking in Play button. It is not something automatically done after you harvest/plow/plant. ![]()
#623
a crop that could be added would be cantaloupe,,
#624
Hi Carol,
I moved your post from Suggestions to answer you. We already have Cantaloupe as a crop.
#625
I have had an ongoing issue for a long time, and I can't figure out what's going on. On three of my farms, #16, #18 and #23, there is an area on all of those farms that, no matter what I do, there is an issue using the tools. This occurs on those three farms in the same spot. When I use the harvest/plow/sow tool, in those specific spots, it's only harvests/plows/sows one individual plot at a time. All the plots are butted up against each other, so the tool should work as it does on the rest of the farm. But, it works normally all around those certain plots, but then I have to do each of those plots individually, one at a time. I have even gone as far as to delete ALL the plots in that entire section, and then replow them, but it still happens...those individual plots have to be done one at a time. Any idea what's going on? Thanks! (I hope I explained that well enough)
#626
![]() Quote:
![]() I just visited your farms but as they are completely planted I cant see which plots you are talking about. Do you use those farms for quests? If so, and you harvest some plots for your quests, then if you replant using the Crop Replanter tool, those plots will not be done. If that is not your problem, then you will need to delete all plots in those farms and then click in Play button. See is any plots then show up. If so, you have to delete them and refresh the farm again. You need to do that till no plots show up and then you can plow again.
#627
![]() Quote:
I have deleted those plots, and a lot of the surrounding ones, replowed that area, and it still happens. I will have to try your suggestion of deleting ALL the plots on that farm, replow, and see what happens. Thanks! |
#628
![]() Quote:
![]() It is not only delete and replow. If there is a problem with those plots, that will not work. You have to delete the plots and Refresh the farm to see if any plot show up. If you see plots after refreshing, you need to delete them and refresh the farm again and continue doing it till after refreshing you only see green grass. Then you can replow the farm.
#629
I used to be able to do multiple layers using the one tab method. That no longer works for me. I have cleared cache and meme cache.
Someone in one of the groups said my farm might be corrupted. How do I fix that? There is nothing on that farm (#48) but crops. Last edited by Taz D; Aug 23 2024 at 10:45 AM. Reason: Removed layering instructions |
#630
![]() Quote:
Please provide the ID for your farms. You can find that at the bottom of your farms page. Being a new farm and if you have not done a lot of layering of things over crops on that farm I do doubt it could be corrupted yet. That usually happens if a farm has been heavily layered and reworked a lot.
Tags |
can't plant, can't plow, can't see crops, crop growth times, crops, farm stats, harvest, harvesting, harvesting crops, offline, plant, plow, seeding |
Display Modes | |
