  #2071
Old Aug 05 2023, 07:26 AM
Originally Posted by Julie Mc View Post
My game is not loading either. This is the error message.
2023-08-05 05:38:06.439 ERRORwasm streaming compile failed: TypeError: Could not download wasm module
2023-08-05 05:38:06.441 WARNWebAssembly streaming compilation failed! This can happen for example if "Content-Encoding" HTTP header is incorrectly enabled on the server for file https://cdn.slashkey.com/flash/farm/...ild531.wasm.gz, but the file is not pre-compressed on disk (or vice versa). Check the Network tab in browser Devtools to debug server header configuration.
2023-08-05 05:38:06.444 ERRORfalling back to ArrayBuffer instantiation
2023-08-05 05:38:21.270 LOGboth async and sync fetching of the wasm failed
2023-08-05 05:38:21.273 ERRORboth async and sync fetching of the wasm failed
2023-08-05 05:38:40.431 ERRORfailed to asynchronously prepare wasm: TypeError: WebAssembly.instantiate(): Argument 0 must be a buffer source or a WebAssembly.Module object
Hi Julie Mc,
Your farms are loading fine for me. Have you already done the routine things like computer and browser updates, clearing etc? If not please make sure that you do those.
I have temporarily turned off all your show items (crops trees etc) so you have less to load when you next try. If you can load the game now please also open your preferences and make the following changes before you show things like crops and trees etc......
  • add a check mark to Freeze animals
  • remove the check mark for Show animals when not at home
  • then click the green check mark to save the change
Animals can be a huge drain on resources for some computers if they are out on farms instead of in animal sheds and also moving around. See if that helps.
Old Aug 06 2023, 05:24 PM
mbcashman mbcashman is offline
Default where is the link for clearing memcache
clearing memcache
Old Aug 06 2023, 05:27 PM
Originally Posted by mbcashman View Post
clearing memcache
Hi Mbcashman,
I moved your post to the thread about loading issues. You can find the link for memcache clearing in the link in the first post of this thread.
Here is the link to that post:
Old Aug 06 2023, 08:15 PM
vonalm vonalm is offline
hello everybody
i need help as i have the usual problem and can't get onto my farm. i went through the usual steps but nothing works
2023-08-07 01:09:16.570 INFOCheckpoint-B-000 - Initialized
2023-08-07 01:09:16.571 LOGFT Client Services Inited.
2023-08-07 01:09:16.589 LOGSessionId: 7062109
Browser: unknown: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/115.0.0.0 Safari/537.36
GPU-Renderer: ANGLE (Intel, Intel(R) UHD Graphics Direct3D11 vs_5_0 ps_5_0, D3D11)
2023-08-07 01:09:17.750 LOGnavigator.mediaDevices support available
2023-08-07 01:09:32.745 ERRORwasm streaming compile failed: TypeError: Could not download wasm module
2023-08-07 01:09:32.746 WARNWebAssembly streaming compilation failed! This can happen for example if "Content-Encoding" HTTP header is incorrectly enabled on the server for file https://cdn.slashkey.com/flash/farm/...ild541.wasm.gz, but the file is not pre-compressed on disk (or vice versa). Check the Network tab in browser Devtools to debug server header configuration.
2023-08-07 01:09:32.747 ERRORfalling back to ArrayBuffer instantiation
2023-08-07 01:09:44.779 LOGboth async and sync fetching of the wasm failed
2023-08-07 01:09:44.780 ERRORboth async and sync fetching of the wasm failed
2023-08-07 01:09:44.782 ERRORfailed to asynchronously prepare wasm: TypeError: WebAssembly.instantiate(): Argument 0 must be a buffer source or a WebAssembly.Module object
thanks <3
http://apps.slashkey.com/farmtown/pl..._id=1830027057
<a href=http://i60.photobucket.com/albums/h15/vonalm/Farm%20Town/CooksCove-1.jpg target=_blank>http://i60.photobucket.com/albums/h1...ooksCove-1.jpg</a>
playing FT since 24th of June, 2009
Old Aug 06 2023, 08:22 PM
Originally Posted by vonalm View Post
hello everybody
thanks <3
Hi Vonalm,
Since I don't know what usual steps you have done, Please make sure your browser and computer are up to date. If you need to do any updates please be sure you have restarted your computer for those to take affect.
If that isn't it then try all the suggestions in the first post of this thread and all of those in the link in that post.
I just loaded your farms without any problems.
Old Aug 06 2023, 08:33 PM
Hi Vonalm,
those are the usual steps, including a run of the CCleaner and an Avast scan and update
thanks <3
Old Aug 06 2023, 08:49 PM
thanks <3
Hi Vonalm,
Avast is known to block outside links so it may be that it is blocking those. Try disabling your Avast and see if it will load.
Old Aug 06 2023, 08:54 PM
thanks Taz, ill take that into consideration but just like magic i had no more error....
have a good night or day and thanks for your help <3
Old Aug 07 2023, 10:29 AM
OutbackAnnie OutbackAnnie is offline
For the last month I have been having loading issues, crashes, "an embedded page at slashkey says WebGL ..." Today I was unable to get on at all. My browser was current, I had just cleaned my memecache. I was using Google Chrome which I had done for years.
On a lark, I decided to try a different browser. Not only was I able to load swiftly, I was able to work all my farms, all my super neighbors farms without any problems and quickly. My suggestion is to ditch Chrome and try a different browser like I did.
Old Aug 08 2023, 09:00 PM
VondaK VondaK is offline
Was in earlier. No problem. Now I'm getting this error twice:
2023-08-09 01:52:04.999 ERRORwasm streaming compile failed: TypeError: Could not download wasm module
2023-08-09 01:52:04.999 WARNWebAssembly streaming compilation failed! This can happen for example if "Content-Encoding" HTTP header is incorrectly enabled on the server for file https://cdn.slashkey.com/flash/farm/...ild542.wasm.gz, but the file is not pre-compressed on disk (or vice versa). Check the Network tab in browser Devtools to debug server header configuration.
2023-08-09 01:52:04.999 ERRORfalling back to ArrayBuffer instantiation
Got it. Might be because of the new stuff being pushed out.
cannot load game, farm not loading, farm town not loading, frequent crashes, game freezes, green screen, loading issues, saving data, u00, webgl, white screen, x025, x025 error
