  #1701
Old Mar 08 2025, 02:52 PM
Originally Posted by Ellsinore View Post
Thank you for this information! These are apparently coin facilities as there are no warnings. But what about the Farm Stats? Shouldn't they show up there if there are two of them on the farm?
Yeah, made that mistake already last week. :-D
Hi Ellsinore,
No sorry, neither farm stats or the facility manager is capable of showing duplicated facilities on a farm. Farm Stats for Facilities is intended to show you which farms have a facility on them, if you have 2 on different farms it can show you that, it can not show you when 2 of the same facilities are on the same farm.
The method that can show you when 2 Farm Cash facilities are on the same farm is only for Farm Cash facilities and uses a considerable amount of resources to be able to do it. Had it also been implemented for coin facilities as well that can cause a problem with the game to run slower for everyone so will not be added at this time.
You might find it easier to hide everything except facilities and do a visual search of each farm and see if any look the same or similar. If you do, mouseover one of them to get that facilities name then use the search tool in your toolbox, type in the name of it and use hide all non-matching items to see if there is more than one.
Old Mar 09 2025, 09:06 AM
Lessonlady Lessonlady is offline
Send a message via AIM to Lessonlady Send a message via Yahoo to Lessonlady
Question Filling Premium fodder and supplement factories
I have bought and stocked all the facilities necessary to create premium food for my poultry, cows, sheep and llamas. But the facilities are always empty and I don't know why! I need more supplements and have all the supplies for them but they don't make enough. How do I remedy this?
Old Mar 09 2025, 09:28 AM
Hi Lessonlady,
I moved your post to the thread about facilities. The Premium Fodder Facility are just like the other facilities in that it make take more of those that supply its ingredients than just one supplier.
Old Mar 09 2025, 10:10 AM
I own 4 premium Fodder Factories and 5 Feed Supplement plants! I have thousands of all of the crops needed for these but I still can't get them to produce what I need. Any suggestions?
Old Mar 09 2025, 10:21 AM
Hi Lessonlady,
The Feed Supplement Plants are non-workable facilities so they can not be worked at the same rate as the premium fodder so you are not going to get enough of the feed supplements to fill 4 Premium Fodder factories with only 5 of the feed supplements and keep them filled.
Old Mar 11 2025, 01:09 PM
nickieshow nickieshow is offline
Default offshore Rig
Can the Oil Refinery and the Offshore Oil Rig be placed on the same farm?
Old Mar 11 2025, 01:12 PM
Hi Nickieshow,
Yes they can as they are 2 different facilities even though they both produce the same product.
Old Mar 18 2025, 12:57 PM
PapaDoe PapaDoe is offline
Is there a list that shows what factories supply products for other factories. I would like to know where the contemporary pharmacy gets its stocking products from. Just want to make sure I don't have to purchase a lot of other factories just to stock the Pharmacy. I know the items it requires, just didn't want to have to spend unnecessary time searching for their factory origin when it has already made available. Thank you .!!
Old Mar 18 2025, 01:53 PM
Hi PapaDoe,
We have lists of which products are stocked where and what facility makes a product and if it's used to make something else or not in Chapter 27 of in the game guide, link if you would like to take a look:
https://www.slashkey.com/forum/showthread.php?t=644326
However when a service facility needs products made in more than one facility those may not be the easiest method for you use.
What you can do is search for the facility in the store then click on the question mark on the contemporary pharmacy.
The first window shows you what it stocks with the picture of that facility at the top right of the window.
To see where each of those products are made you would then click on a product picture in that window and the information will change. Not only will it show what it needs to make that product but if you look top right you will see a different facility which is the one that makes that product. You would need to do that with each of the products stocked in the Contemporary Pharmacy to see if more than one different facility was needed.
How to use the question marks on a facility in the store before you buy is in Chapter 13 Facilities in this post:
https://www.slashkey.com/forum/showt...94#post6298294
For speed as those take time to go through, the Contemporary Pharmacy Store does require products to be made in 2 other Farm Cash facilities which are the Medical Supplies Factory and the Personal Care Good factory.
Old Mar 24 2025, 12:03 PM
honeyg56 honeyg56 is offline
Default Facilities
When doing facilities "work both" is not working. It doesn't do the service facilities. It goes through the motions but doesn't actually do them
belt, can't post from facility, cash out, display issues, duplicate facility, facilities, facility manager, facility wall requests, find facility on farm, fuel problems, fuel usage, funeral facilities, ingredient planner, levels, load all, mineral mine glitches, non-workable facs, offshore oil rig, production facility, religious facilities, service facilities, service facility, store all, tool glitches, what's in stock, what's pending
