  #81
Old May 04 2024, 06:38 PM
Originally Posted by TexasStar View Post
I set certain quest farms with the Harvest Time in the Super Neighbor Manager. My super neighbor replants the quest plots with the same crop, then plants the balance of the farm with the crop for that harvest time that is lowest in storage. When the Super Neighbor selects the Harvest-Plow-Sow tool she cannot choose the Crop Replanter Implement...where the Green text box should be, there is a Blue text box "+Add Cash & Coins". If this could be changed to allow use of the Crop Replanter, it would help.
Setting Replant Same Crops in the Super Neighbor Manager doesn't allow her to plant harvested fields and of course she cannot change to normal harvest-plow-sow tool to plant the desired crop on the rest of the farm.
If the Crop Replanter is used on quest farms, where plots have been harvested for quests, Super Neighbor can turn off the crops or choose the planter but with the crops not showing it is difficult to know what belongs in those spots, making it time consuming to use Crop Replanter on quest farms.
The way things are now, we have had to abandon this expensive but promising tool. My Super Neighbor has also had to abandon the one she bought for her Super Neighbor for the same reasons.
Hi TexasStar,
If I understand what you are saying, it is not the replanting of existing crops that is the problem. It is the plots that have been used for quests and either left as harvested or plowed. There isn't any way for the replanter to know what was planted in those plots after they have been harvested.
You can make a suggestion if you post it in the Suggestions section for a change to this. You can not start a new thread there but you can reply to an existing thread that fits your suggestion.
  #82
Old May 04 2024, 07:53 PM
TexasStar TexasStar is offline
Hi TexasStar,
No, that was not my main issue. I know and understand that. I mainly mentioned that because it was described as good for quest farms but may be significant drawback for others as well.
The part that I think is a mistake is when farms are are set in Super Neighbor Manager (SNM) for Harvest Time, instead of the green text box for selecting the Crop Replanter Implement, there is a blue textbox that says: "+Add Cash & Coins".
(Setting Replant Same Crops in the SNM won't work because SN cannot plant the rest of the farm not used by quest crops with the crop lowest in storage.)
Thanks for the quick response.
  #83
Old May 04 2024, 08:06 PM
Hi TexasStar,
You can only have the SNM set to one or the other. It is not possible to set it to more than one setting. There isn't any way for the developers to change that.
As I said if you have a way to make it work the way you want it to work then make a suggestion for a change to how the tool works and post it in the Suggestions section.
  #84
Old May 04 2024, 08:50 PM
Hi TexasStar,
I understand that I can only select a single option in the SNM.
Example: I set SNM for Farm 29 to "Any 1-Day Crop". When SN is on that farm and selects the H-P-S tool it opens the Crops ... above the crops where I expect to see Green box saying "Replant Same Crops" it has a Blue box saying "+ Add Coins & Cash". I think this must be a mistake since the coins for planting on my farm are charged to my farm, so the SN would have no reason to need to add coins or cash from the crop selection screen. I think it should be the "Replant Same Crops" box. This would be consistent with the screen SN gets on a farm set in SNM for "ANY".
  #85
Old May 04 2024, 09:06 PM
Hi TexasStar,
Ok, I see what you are saying. No they would not need to or be able to add coins. We will ask the developers about this. It may be that it should not have either as we don't know what there thoughts were on this.
  #86
Old May 04 2024, 09:54 PM
Hi TexasStar,
Taz, thank you for sticking with me on this! I just found a work-around for the harvested quest fields, so if the developers can change that box my SN can use the new Crop Replanter!
  #87
Old May 07 2024, 08:39 AM
Patti Coop Patti Coop is offline
Default Replanter Tool-Thank you!
Hi, I just wanted to say thanks... this tool is perfect for quest farms and will save me a lot of time! Genius! Thanks to the developers!
  #88
Old May 07 2024, 11:17 PM
wvmilkman wvmilkman is offline
Wink The Replanter is Awesome!
I bought a crop re-planter to go with my orange combine-harvest-planter and it is a huge timesaver! What used to take me three hours to do at night I can now get done in about 30 minutes get to bed at a more reasonable hour. A super-neighbor friend of mine gave me a heads up about it a few nights ago and I bought one right away. Yeah, it's a bit pricey—but to me it was well worth it.
  #89
Old May 08 2024, 11:31 AM
RomanticSoul RomanticSoul is offline
Hi RomanticSoul
I understand what you are saying but this tool doesnt work for harvested and plowed fields as it is impossible to know which crop was planted there before it was harvested.
The tool cant assume that it was the same crop planted around the harvested area.
Makes no sense. since were essentially using the same tool we used before to plant. which is a harvest plow and plant combine. all in one click. And since this tool doesn't do that this new plant all. now i gotta hunt for what product was missed. go back to the store and replant. for the 12 quest farms I do. 4 farms for 3 different people that have 1 hour to 4 day crops planted on them. Should be able to plant the same crop that was harvested.
and when using this replant all tool were not telling it what to replant...so how does it know what to replant?
  #90
Old May 08 2024, 11:37 AM
Originally Posted by RomanticSoul View Post
Makes no sense. since were essentially using the same tool we used before to plant. which is a harvest plow and plant combine. all in one click. And since this tool doesn't do that this new plant all. now i gotta hunt for what product was missed. go back to the store and replant. for the 12 quest farms I do. 4 farms for 3 different people that have 1 hour to 4 day crops planted on them. Should be able to plant the same crop that was harvested. and when using this replant all tool were not telling it what to replant...so how does it know what to replant?
Hi RomanticSoul,
I am sorry, but once the crop(s) planted on a farm have been harvested then that data is no longer in the database for that farm. So there isn't any way for the replant to know what crops were planted in what plots if they are harvested and/or plowed.
When you use the replant tool it knows what crop to replant because that information is in the database as what crop is planted in what plot. So it harvests and replants the same crop in that plot all at once. That only can happen if there is a crop that is ready in that plot.
