Register FAQ Calendar Today's Posts Search
Old Oct 20 2009, 02:36 PM
Raul Raul is offline
Default New Release -- October 20th, 2009
Hi,
We just released a new version of FarmTown. (As usual, you will get the new version when going to FarmTown the next time).
The new release contains support for 5 different tools:
1. Small Harvester - Harvest 2 fields at a time
2. Small Seeder - Plant seeds on 2 fields at a time
3. Big Harvester - Harvest 4 fields at a time
4. Big Seeder - Plant seeds on 4 fields at a time
5. Plowing Tractor - Solar Powered - Plow 4 fields at a time
All the tools works in a similar way, you just need to click on the tool and select the first option which could be Harvest, Plant Seeds or Plow depending on the tool. Alternatively, some of the tools can also be activated by clicking on the appropiate icon on the main tool window at the bottom of the screen.
The Plowing Tractor doesn't require fuel to operate so you can use it as much as you want without any limitations. The others require fuel to operate, these are the rules for the fuel:
1. To get fuel you need to go to the fuel station by clicking on the red fuel tank on the top-left of the screen or on the map icon
2. You can refuel once per day
3. The amout of fuel gallons you receive each day depends on these factors:
10 Gallons for each level you have accomplished
10 Gallons for each neighbour you have
10 Gallons for each friend you help each day
10 Gallons for each active neighbour in the last 24h
100 Gallons for each fuel tank you receive from your friends
If you are having trouble, remember to link your account.
Thanks.
Moderator Edit: We have an established thread in the help and support section where we will attempt to answer any questions that you have about these new features. http://slashkey.com/forum/showthread.php?t=238278 Mods will not be answering questions posted in this thread from the developers.
