#231
mine still hasnt re apeared, cant even pull up how many i got, , oh well another day on ft |
#232
i'm loving the last several updates we've had, but please, PLEASE consider making bigger flower and tree harvesters soon!!! i think we really need them!
http://apps.facebook.com/farmtown/pl...3439&farm_ix=Y |
#233
How do you know if your neighbourhood chain is chosen?
My Farm: http://apps.facebook.com/farmtown/pl...4007&farm_ix=0 Farming since: 14 December 2009 |
#234
Hi FarmerWitch
If you open your yellow tool box and then click in the bright blue dice for Neighborhood chains contest, you will see 3 buttons at the top of that screen. Click on the third one (Neighborhood Ranks) and you will see your avatar picture, your avatar name and your rank (your position). You can also see you rank at the botton left of that screen in green.
#235
Is there any chance of reducing the number of clicks required to work the facilities in the Neighborhood Chains Contest???? Currently, it takes 5 clicks per facility, not counting the clicks to open and close the contest itself. Those of us with carpal tunnel symptoms appreciate any moves that reduce clicks.
#236
The #1 neighborhood in the chains contest that we are competing in has 20 more facilities in it than ours does. Dont see ever winning in that.
https://apps.slashkey.com/farmtown/?farm_id=1557855304 |
#237
That is not necessarily a disadvantage. For example, the neighbourhood winning in my contest has less facilities than we do. It's all about the points you make keeping those contest facs loaded. The more often you and your neighbours load/produce in those contest facs the more points you get for your neighbourhood.
Tiger Clickable Help Links:
Need help? Post in Help and Support How to get and Create your Farm Link How to FIND YOUR POSTS on the forum. Last edited by Tiger; Apr 11 2016 at 06:38 PM. |
#238
on the neighborhood contest it says I have only one dairy processing plant I have more than that I have 5 why are they not showing up?
#239
I may be in the wrong spot to ask this, but is anyone else having issues with Firefox and not able to update the flash player for it?
FIXED IT!!! Last edited by Aussie Rae; Apr 12 2016 at 02:15 AM. |
#240
The rule is that for every Farm Cash facility the contest requires, you can have the same amount of coin facilities in the contest. I had a look at your data and you dont own any of the farmcash facilities requiered this week (Boat Yard and Nutritional Supplies factory), so you can only use 1 of each of the coin facilities.
