![]() Quote:
Tiger Clickable Help Links:
Question about the Turbo Tools for Service Facilities?
Do these two tools cover all of the service facilities that are on FT? thanks! |
Will not let me irrigate, only water. Not even that if I don't have flowers on the farm. Have to pull my old one out of storage, place on farm to irrigate. That way I get all the options the purple one has.
Also Purple will not let me do single farm. |
![]() Quote:
In the meantime you can take the sprinkler out of storage and place it on the farm to use or if you have a bit of patience there is a method you can try but it does take a bit of fiddling about......... In the extended toolbox, hover over the sprinkler around the midpoint and slowly move the cursor towards the top, you will see the box shift upwards, by a tiny amount, when it does that click on it and you should grab the upgraded sprinkler to use. When you get the menu pop up, there are 2 tabs, "Select one farm" and "Select multiple farms" to chose from.
I was very happy with the addition of the Turbo Tools for the Service Facilities, loaded them this morning and was so much quicker. However, I have just reloaded my facilities, click on the 'Load All' button first, then loaded up the other facilities, was not really concentrating and realised I had gotten down to the Service Facilities, and without exception I could load each one up individually to a much higher % than they had been loaded by the tool, some were loaded at 40% and when I clicked individually they went to 100% ??? I will keep a watch on this for the next couple of times I load them. I would have assumed that the Turbo Tools would load them as much as was possible with the stocks available???
Hi,
The developers are aware of the sprinkler issues and are looking for a fix. In the meantime you can take the sprinkler out of storage and place it on the farm to use or if you have a bit of patience there is a method you can try but it does take a bit of fiddling about......... In the extended toolbox, hover over the sprinkler around the midpoint and slowly move the cursor towards the top, you will see the box shift upwards, by a tiny amount, when it does that click on it and you should grab the upgraded sprinkler to use.
![]() Quote:
http://apps.facebook.com/farmtown/pl...794&farm_ix=15 It's a game, not a competition...enjoy at your own pace. Blessed are the thin-skinned for they shall make life miserable for everyone else. Google Chrome WF40 Farming since 3/31/09 |
Where can I find the current Levels and their associated/necessary Experience Points?
Also does the Experience Points display have a limit on the number of digits displayed? I'm at level 400 and I see neighbors in the little display at the bottom who seem to have fewer experience points than I do but are, say, at level 385. Or is it possible that I am missing a digit in my display. I see 25047630 Is that 25,047,630 or is it 250,476,30? I'm a little confused since I haven't been paying much attention to it. Gary |
![]() Quote:
![]() Quote:
My Server: WF-36 on Windows 8 Primary Browser: Chrome To contact Support: Click Here. Information on how to clear several browser's cache: Click Here. If you have a question please post them in the open forum and not in a private message or visitor message, unless it is in response to a private message. Thank you.
