#101
Thanks for the update.
Doc |
#102
small glitch, made the quests better with a link, made the co-op quests worse as now its doesn't tell you what facility you need for the final loading of the facility. Can it be fixed please.
#103
This has already been reported to the developers. We are just waiting on them to fix it.
#104
The link to the facility being used for the task is great. What also would be great is if a crop or tree is to be harvested, there is a link to the farm the item(s) are located on. I have trouble remember where I put the darn things. THANK you for the link to the facility!!!!!
#105
In 10.6 hours I will lose my first quest as I cannot not find the facility to start them, I tried all the facility and found the right one after an hour n a half I clicked on it to begin the quest and checked and lo and behold it has not started after all I have 6 quests waiting to be started now what happens when time runs out???
I now have only 11 Minutes for 1 to be lost Well I lost my first Quest and I have 2 Days to the next one 1.2 days to losing my Second Quest( Dose Any1 Care) Last edited by iceberg; Feb 16 2015 at 11:30 AM. |
#106
i know its long winded but if you find the item you need to make and go to your storage and click on it, it then shows you which facility you need to make the item and then go to the facility and start it then, it does take some time, specially if you have a few, the other alternative is, load all your facilities, probabilities are you will start them all then anyway lol
#107
problem since the update on the quest cooperative Dé Bleu we do not see the name of the plant to produce hard research in our plants which must produce
#108
1. The devs are aware and we're all waiting for a fix Les développeurs du jeu sont au courant et on attend tous qu'ils corrigent le pépin 2. check what the last step facility is before starting any of the other steps verifiez quelle usine/magasin est la dernière étape avant de commencer la quête. Dès qu'on la commence on ne voit plus le nom. 3. click the question mark on the needed item in your storage to see which facilities produce and stock it ouvrir votre entrepôt et cliquer sur le point d'interrogation vert pour savoir quel usine fabrique le produit et quel magasin le vend Hope that helps some |
#109
