Originally Posted by Chihuahualady
(Post 5178146)
I have been doing the quests since they first started and have had to let at least 3 quests expire because of not having the facility needed to complete it, I have never been able to see the icon of the facility needed to complete before I start, the only time I see the icon is when I am going to the next step of the quest.
Quite honestly I don't see the quest cube as a Mystery Dice for the quests, but just as a chest making you curious to open, and in my opinion you shouldn't have to waste your time going through the quests only to find you can't complete it.:)
You have to make a couple of clicks to see it. For instance, yesterday I had to 'load 25 x coconut ice cream into a service facility'. By clicking on the final step, top left box, which showed the coconut ice cream, I opened a box that showed the ingredients. But on the top right hand corner, it shows the product and the factory that is required to make it in. If you hover over that factory facility it will actually tell you if it is 'owned' by you already. Then in blue underlined writing on the very top left of that screen, it says '
see what facility to stock with coconut ice cream'. If you click on that wording it will take you to another screen that shows you ONE of the facilities that loads coconut ice cream, and again, will show you if you own it.
Sometimes, a product can be loaded into more than one service facility, and it is here you can get caught, because the screen will only show you one of them, and it is not necessarily the one they require you to use at the end of the quest.
Another way to check then, is to go to the factory that makes, for this instance, coconut ice cream, and click on the product. That will bring up another window that will show you the ingredients needed, but again, at the top of the screen in blue underlined print is '
See what facilities to stock with Coconut ice cream'. This will show you ALL facilities that can be loaded with that ice cream, and if you only own one of them, you can either not begin the quest, or take your chances and hope the final step asks you to use the one that you own. In the case of coconut ice cream, it is only stocked in the Food Fair stand, so you know exactly which facilities are required BEFORE beginning the quest.
Oh, and the advice that Rob gave you about using the Game Guide with (ctrl + f) works brilliantly to check out what you need.
Hope this makes sense :)
