Hi lyndalu47. If those flags were animated, then they have not been added to the game yet. Patience :)
Hi Deanna J. Lloyd, There are a couple of things that it could be down to: Currently when working your own farms, you need to reload the game after working to for the quantities to update. If you are used to hiring your work out rather than doing your own, then you won't be getting as many due to not having the extra boxes as a reward for hiring a farmer from market. |
100000691604893 user id
I am missing llama (I have 105) and sheep (0) in my wool shed on farm 41 I may be having an issue with harvesting stables,chicken,and dairy buildings on farm 1. said they were ready to harvest but no amounts were seen when they were harvested. I will check them again day after tomorrrow. ty for all you are doing - sure do miss the game and people. :) |
The missing llama we will have to wait until those animals are added back into the game and you can view what's in them. I'm seeing you have 104 for that farm. You may be getting one less than usual if it's on the farm rather than in the shed and as those animals are animated, those have not been added back yet. Farm 1 is not displaying the information about what's being harvested, but they still should be adding to your storage amounts fine. Next time you harvest the ones on that farm, make a note of what animal products you have in storage, harvest them, then if they don't get added right away, reload and check if the amounts have gone up. |
Not sure if this is the right place for this, when I move something to a different place if l try to put another item in it's place it is still showing up the item l moved l can click on it and it shows it is still there and l cannot high light any thing around it to move, thank you
I was able to reproduce the issue in part I think. When you say that after moving an item it still is showing up, do you mean you have 2 items of the same kind in 2 different places? Which method were you using to move the item? When I tried, the item I moved only shows up in the new place, and only its name is showing up in its previous place. That way I was able to place a new item in that place as it is not occupied, it is only showing up the item name. If you refresh the farm, all back to normal. |
Working my farm today, I noticed that I had planted three farms to scallions instead of sorghum. This isn't the first time this kind of mistake has happened in the HTML version. I really don't think it's down to me entirely because it didn't use to happen in the Flash version.
It isn't obvious when you select a crop to plant that it is actually selected. It doesn't highlight or anything. I tend to come at the list from the side directly onto the crop I want then hover the mouse for a few seconds because of this, but clearly that's failed me on this occasion. |
Hi Sqrl and Grumpdad :) We are aware that if you use the search for crops, it only works for the farm you are at that moment, when you go to other farm, the option doesnt stay and you have to search again. But I dont know which options you have set for the funnel and the A/Z icons I tried All and Alphabetically to try to reproduce Sqrl issue and Scallions are just above Sorghum but Sorghum was planted correctly for 3 of my farms. For Grumpdad : Please check your stored amount before and after harvesting. And you have to reload the game to get all harvest correctly added to storage. |
