What is up with the game not loading, i got home last night from work and it would not load for several minutes (not sure how long 10 , 15 maybe 20) and then it loaded, got up around 7:30 this morning and it would not load again. This has been going on for a few days now.
I moved your post to the Help & Support thread about loading problems. The developers are aware of the issue and are looking into it. |
Game not loading
Game not loading again.
Correction my game just loaded up |
You are both right, the developers are investigating what is happing but it is not easy as it is intermitent. Please try loading the game again, it is ok for me just now. |
Game not loading
1 Attachment(s)
Along with everyone else, I'm having the intermittent issueof the game not loading. However, BEFORE THAT, I was having problems getting past the screen down below. It just freezes right there. I have installed the new INTEL graphics driver and I have also an app that notifies me if there is a new one.
Help! |
The developers are aware of the problem but it is intermitent so they are having a problem pinpointing the cause of this. The only thing you can do is leave it open and it should go ahead and load eventually. If it doesn't close it and try again. |
What about the error message I sent you the picture of in the attachment? It's been happening for a while now.
Do your farms normally load even with that error? That is not an error message. I misread what it said. It is just telling you that it is working. A LOG entry is not an error. |
My game is not loading either. This is the error message.
2023-08-05 05:38:06.439 ERRORwasm streaming compile failed: TypeError: Could not download wasm module 2023-08-05 05:38:06.441 WARNWebAssembly streaming compilation failed! This can happen for example if "Content-Encoding" HTTP header is incorrectly enabled on the server for file https://cdn.slashkey.com/flash/farm/...ild531.wasm.gz, but the file is not pre-compressed on disk (or vice versa). Check the Network tab in browser Devtools to debug server header configuration. 2023-08-05 05:38:06.444 ERRORfalling back to ArrayBuffer instantiation 2023-08-05 05:38:21.270 LOGboth async and sync fetching of the wasm failed 2023-08-05 05:38:21.273 ERRORboth async and sync fetching of the wasm failed 2023-08-05 05:38:40.431 ERRORfailed to asynchronously prepare wasm: TypeError: WebAssembly.instantiate(): Argument 0 must be a buffer source or a WebAssembly.Module object |
